1992 Geo Tracker fuel injector
CHAD4664
Electrical problem
1992 Geo Tracker 4 cyl Two Wheel Drive Manual
I have no power at my fuel injector. I checked the fuses and they are ok. I checked the voltage that the computer, injector and it was 1.6 volts.Is that the correct volts for a injector.
Sep 29, 2010 at 12:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
need to check resistance across the fuel injector terminals. the ohms should only be 1-2 , anything else then injector needs replaced.
Sep 29, 2010 at 1:40 PM
