#2 cylinder has zero compression, while other three have 80 PSI compression. Vehicle dies when ever you come to a stop and runs rough (running on three cylinders).
Does this mean piston rings are bad, or possible hole in piston? I tried pouring little amount of oil in bad cylinder and rechecking compression...still zero pressure.
Does this mean enigne needs rebuild...if so can I replace just that piston or all?
Thanks for the help, Gary
Sep 15, 2008 at 7:46 PM
