1991 Geo Tracker Zero Compression in one cylinder
135,000 MILES • 4 CYL • 2WD • MANUAL
GLOVERGS
#2 cylinder has zero compression, while other three have 80 PSI compression. Vehicle dies when ever you come to a stop and runs rough (running on three cylinders).
Does this mean piston rings are bad, or possible hole in piston? I tried pouring little amount of oil in bad cylinder and rechecking compression...still zero pressure.
Does this mean enigne needs rebuild...if so can I replace just that piston or all?
Thanks for the help, Gary
Sep 15, 2008 at 7:46 PM
  • 31,937 POSTS
Hi there,
If it had a hole in a piston it would be burning clouds of smoke, i would say you have a burnt or stuck valve, check this out first.
mark (mhpautos)
Sep 15, 2008 at 9:57 PM
