1991 Geo Tracker steering column ground
MUZ14
Electrical problem
1991 Geo Tracker 4 cyl Four Wheel Drive Automatic
where is the original ground location for the steering column? Required to operate horn.
Mar 17, 2009 at 3:31 AM
RACEFAN966
  • 5,029 POSTS
It is all part of the 20 wire harness coming down the column as the ground is not actually on the column it self. So if you would like to test the horn then get back to me and have a test light and a digital multi meter and we will run a couple of test. There is one ground that comes off the horn itself.
Mar 17, 2009 at 4:12 AM
