1990 Geo Tracker Car died and won't start
83,000 MILES • 4 CYL • 4WD • AUTOMATIC
SHERPAT
Our GEO begin to be slow to crank and then one day it stalled and never would start again. It will crank over but not start. WE replaced the fuel filter and had the fuel pump checked to see if it worked , changed the fuel injector but it still will not start. If you poor gasoline directly into the carberator it will start briefly. If you pull the hose going into the carbrator the gas is flowing. Someone said we should check the inertia switch where is that located
Oct 4, 2008 at 2:09 PM
IZTHEWIZ202
I have the same problem. It will crank fine but not start. Fuel is getting to the carburetor. It will start when a shot of gas is poured into the top of the carburetor but only runs briefly. I have checked the ECM (it's fine), I have checked all of the fuses and relays and I have even replaced the whole carburetor with another but still not starting. Any suggestions?
Jul 27, 2012 at 11:03 AM
