1994 Geo Storm
88,000 MILES • 4 CYL • FWD • MANUAL
CHEVY_WIGINTON
The car will turn over but not start. I can hear the fuel pump turn on and the battery is fine. What could it be.
Jan 7, 2009 at 12:33 AM
VBOSS5764
  • 23 POSTS
[quote:3864cb3081="chevy_wiginton"]Engine Performance problem
1994 Geo Storm 4 cyl Front Wheel Drive Manual 88000 miles
The car will turn over but not start. I can hear the fuel pump turn on and the battery is fine. What could it be.[/quote:3864cb3081]
Ok, first, the Storm stopped production in 93. First check for spark, pull a plug and insert a screwdriver or spark checker if you have one, hold the screwdriver close to a ground, ie, engine metal part, have some one turn the engine overand check for fire. Or you can try a blast of starting fluid in the intake, if it fires you have a fuel problem, if not probably a fire problem, in that case pull the module under the cap and have it tesrted.
Jul 9, 2009 at 4:42 PM
