1993 Geo Storm Jerks in reverse
188,000 MILES • 4 CYL • 2WD • AUTOMATIC
PBALLARD1977
I replaced the right CV axle about a week ago. The car drove fine for several days. Tonight I went to back out of the driveway. I put it in reverse and let it slowly back out of the drive. It jerked suddenly to a halt. I gave a little gas and it wouldn't budge. I put it in drive and pulled forward a few feet. Then I tried again and had the same result. I then tried just putting it in reverse and had the same jerking action. It seemed to drive forward fine. I was able to kind of rock the car while in neutral and got it to move further backward, but shortly it caught again. Any thoughts?
Aug 10, 2009 at 4:07 PM
DOCFIXIT
  • 18,828 POSTS
Hi
check out right brake caliper see if mounting bolts are secure. If O.K. jack up front see if it goes in rev. if good jack up rear rotate wheel to see if it locks.
Let me know
Thanks for donate
Aug 11, 2009 at 2:27 AM
PBALLARD1977
One of the bolts is missing holding the caliper to the steering hub. Now the hard part is finding someone with the bolt in stock.
Aug 11, 2009 at 5:45 AM
DOCFIXIT
  • 18,828 POSTS
Thought that might be it. Most parts houses have replacement bolts in stock.
Aug 11, 2009 at 6:12 AM
PBALLARD1977
I found the bolt at a junk yard. Auto part stores, the dealership, and home improvement stores didn't stock the size I needed. Thanks for your help.
Aug 11, 2009 at 11:24 AM
DOCFIXIT
  • 18,828 POSTS
Good you have a real junkyard all we got here is the botique recycler.
Aug 12, 2009 at 12:59 AM
