1992 Geo Storm will not run
167,621 MILES • 4 CYL • FWD • AUTOMATIC
RANDY2885
help my car will not run i have tyied may different things to get it running again
Nov 10, 2010 at 5:29 AM
  • 75,988 POSTS
Start by doing below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Nov 10, 2010 at 5:35 AM
