1992 Geo Storm car idles and then turns off
1992 GEO STORM
126,000 MILES • 4 CYL • 2WD • MANUAL
ABEL_ROMO
My problem begun just yesterday at wells fargo's parking lot. I jumped in my car and I turned it on and it made a loud popping sound and after that it began to sound as if the engine was knocking. I immediately shut it off and tried turning it on again. It kept knocking so I left it there. I came back later after some advice and looked under the hood and one of the spark plugs was hanging out so I put it back in and tightened the rest of them. My car was also low on engine coolant so I refilled it up. It was overheating like 3 days before this incident. I turned on the car and the engine sounded fine, but now it would idle at 2000 rpms and then it would choke and die. I tried driving it home like that and when I gave it gas it would respond but then it would go down in rpms so i would have to gas it again. After the engine was on for a while it quit dying on me. It was driving just fine. So I am not sure what exactly is going on. Oh yeah the oil condition is just fine. I am confused. i am thinking of taking it into a shop but my budget is very small.
Jun 9, 2009 at 2:09 PM
RACEFAN966
  • 5,029 POSTS
Ok so how it running now? How are the plug wires and how did that plug look? Did look good or was it carboned up and look like the plugs could use replacing? What I would do if all looks fine is disconnect the battery for about a minute and then reconnect it and see how it runs. If it fine then I would just keep an ear out keep the a watch on the coolant and oil level. If it causes no more problems then it will be fiine. Let me know what you can. Thanks.
Jun 10, 2009 at 2:48 AM
