1992 Geo Storm
1992 GEO STORM
XJOSEPH
1992 Geo Storm 4 cyl Front Wheel Drive Automatic
cranks but didn't turn over
Sep 22, 2008 at 11:35 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 23, 2008 at 4:13 AM
