1991 Geo Storm wont start after sitting more than 24 hrs
GREGMAINT
  • 1991 GEO STORM
  • 4 CYL
  • FWD
  • 140,000 MILES
My 91 geo storm gsi will not run if it has been sitting more than 24 hrs. It cranks over trys to lite off but wont. When its all said and done it smells like its flooded.
Friday, January 15th, 2010 AT 1:20 PM
When it refuses to start check if its a fuel or spark problem -Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, January 15th, 2010 AT 3:39 PM
