1991 Geo Storm Low compression in middle cylinders HEAD GAS
STORMRACING7
Engine problem
1991 Geo Storm 4 cyl Front Wheel Drive Manual ????? miles
I have a 90 or 91 geo storm gsi (dohc 1.6). I race the car at a local track. The head has been shaved 20 thousanths. The compression in the outside cylinders are about 230 lbs, but the middle cylinders are about 175 lbs. I replaced the head gasket thinking that would fix it but nope it didn't. Head and block both looked fine. The car has been overheated more than once. Warped head?
Dec 14, 2007 at 9:33 AM
JUSTALUCKYSHOT
  • 10 POSTS
Well, I would start at the basics, so yes, a warped head. Hears a quick check. Put your hand over the muffler. If the mufflers not like a 3.5 inch tail pipe, haha.
Does it suck your hand in?
If a head gets warped, it will try and share the cylinders, so the intake stroke of cyl 3, will suck in the exhaust of cyl 2, or vise versa, intake/exhaust strokes, ect.
Do you know the guys who shaved your head? are they good at what they do?
Also, was the head gasket made for shaved heads?
While the heads out to be milled, check valves. maybe the spring that holds the rocker arm is stuck, causing both 2 and 3 to hold a valve open a little, and if so, that would cause a compression leak.
Again, while the heads out, make sure the threads for the spark plugs arent stripped. you never know.
=D hope I helped
Sep 19, 2008 at 2:30 AM
