1991 Geo Storm Dim headlight
CHARLEYMAN101
Electrical problem
1991 Geo Storm 4 cyl Front Wheel Drive Manual
im going crazy with these lights. when i turn them on the driver side is bright and the passenger side is dim. i was told is was the ground and that there would be three wires coming off the light. and the one without power is the ground and i could just connect it to the frame. there are only two wires coming off each light and they both have power. how am i supposed to connect the ground to the frame without a ground wire. any help would be greatly appreciated
May 12, 2009 at 6:12 AM
VBOSS5764
  • 23 POSTS
You cannot ground these HLs to the frame, for one they are fused on the ground side and two they have a relay on the ground side.
The Red/Green wire is low beam with Red/Blue as gnd, The Red/yellow is high beam with Red as gnd.
Make sure you have the correct head light in each.
Jun 30, 2009 at 1:38 PM
