1991 Geo Storm Altenator
1991 GEO STORM
150,446 MILES • 4 CYL • FWD • AUTOMATIC
HEEZY24
How do I replace my altenator belt?
Jan 16, 2010 at 9:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Except for the 1.8L engine, loosen the pivot and anchor bolts on 1 of the belt's components, then pivot the component sufficiently to release belt tension and remove belt.
2.For the 1.8L engine, use a 3 / 8 in. breaker bar or ratchet to pivot the belt tensioner and release the serpentine drive belt, then remove the belt from the pulleys and the vehicle.
To install:
3.Position the belt over the pulleys.
4.For the 1.8L engine, pivot the tensioner and install the serpentine belt. Make sure the belt is properly aligned in all of the pulley grooves, then gently pivot the tensioner into contact with the belt. Do not allow the tensioner to snap into position or damage could occur.
5.Except for the 1.8L engine, adjust the belt tension and tighten the accessory mounting bolts.
Apr 30, 2010 at 3:45 PM
