Geo Prizm Ignition Locks in Lock
SIRAGUSA
the ignition will lock up in the lock position even moving the steering wheel back and forth doesn't easily help. I'm afraid i'll break the key off if i turn it too hard. Thus, i've been leaving the car turned off in the accessory position but this morning had a dead battery but i've been doing this for about a week.
Jul 16, 2007 at 5:21 AM
BOOTDOG
  • 665 POSTS
try getting a new key made. sometimes a worn key will not allow you to unlock the cylinder. if that doesn't work, you'll need to replace the cylinder.
Jul 16, 2007 at 11:58 AM
Suggested Repair
Have a new key made, since a worn key can prevent the ignition cylinder from unlocking. If a new key does not help, replace the ignition cylinder.
Conversation Summary
The owner of a Geo Prizm reports that the ignition locks in the lock position and moving the steering wheel does not easily free it. They are concerned about breaking the key and have left the switch in accessory, which drained the battery. The expert recommends trying a newly cut key first and replacing the ignition cylinder if that does not solve it.
