1997 Geo Prizm Turn key nothing happens!!!
1997 GEO PRIZM
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
THWRANGLER
Have random problems with my car.....once a week when I go in and turn the key nothing happens.....sometimes it takes 3 or 4 turns and it finally starts.
The battery is only a year old.
What could it be??
Sep 3, 2010 at 1:56 AM
No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Sep 3, 2010 at 2:47 AM
THWRANGLER
When I turn the key nothing happens at all.
Usually I have to take key out and try again....which will usually help!...after a few times.
battery is fine and so are the connections.
Do you know what the cost would be on those items??
thanks for the help......
Also if I don't fix it....will it get worse or just continue doing what it does now??...
Sep 3, 2010 at 2:54 AM
Sounds like the problem is coming from the ignition switch for it to do that-sooner or later its gonna finally quit-get it checked out-dunnno the cost it varies with location.
Sep 3, 2010 at 5:24 AM
