1995 Geo Prizm Worn CV Joints
KWILL1967
1995 Geo Prism Lsi, mileage over 150,000. I just bought the car from somebody who took great care of it; however, I've been told the cv joints are worn. What would you do?
Oct 17, 2007 at 6:12 AM
MERLIN2021
  • 17,250 POSTS
I would turn the wheel all the way in either direction, then look at the axle were it goes thru the hub, in back there is a ribbed looking cover on the joint, is it split? grease all over the place? and does it make clicking noises when you turn while driving? If yes to these questions, replace it!
Oct 17, 2007 at 7:43 AM
Suggested Repair
Turn the wheels fully and inspect the ribbed CV joint boot where the axle passes through the hub for splits and grease leakage. Listen for clicking while turning during a drive. If those signs are present, replace the CV joint.
Conversation Summary
The owner of a 1995 Geo Prizm with over 150,000 miles was told the CV joints are worn and asked what to do. The expert advised checking the joint boot for splits and grease and listening for clicking while turning, and replacing the joint if those signs are present.
