2000 Geo Prizm engine or the air condition
WILLIAM WHEATLEY
Engine Performance problem
2000 Geo Prizm Automatic
when i start up vehicle then cut the air on full blast , i let the car run a few minutes then i pull out the driveway when i go to pull off again it hesitate like it not getting the right amount of gas [like its choking out],or the fuel injectors is slightly clogged , but if i cut down the air to low it goes fine,and it only does it with the air condition on high
Jun 30, 2008 at 1:27 PM
MASTERTECHTIM
  • 4,750 POSTS
does the cooling fan come on when the ac is on?
Jun 30, 2008 at 1:29 PM
WILLIAM WHEATLEY
[quote:2ad17b46c8="mastertechtim"]does the cooling fan come on when the ac is on?[/quote:2ad17b46c8] it also does it now without the air. most likely i believe the fuel iunjectors is dirty or problem with the way its getting or controling fuel because it sometimes takes entirely too long to start when you just got finish driving and go to start up again
Jul 3, 2008 at 12:05 AM
