1997 Geo Prizm Power Windows
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOMEDUSA
All four of the power windows will not work..thier is no sound nothing...I have checked to determine if it is a fuse but I can't seem to find any fuse that controls the windows. All other electronics work fine. I have tried to use the specific door control for the window as well as from the drivers side controls.
Any suggestion would be helpful..one of the windows is partialy down.
Thanks,
Mar 23, 2009 at 10:15 AM
MMPRINCE4000
  • 8,548 POSTS
Check kick panel next to left foot for fuse, there is sometimes another one on the passengers side.
Remove window switch on driver side and check for 12v.
Mar 23, 2009 at 10:40 PM
JOMEDUSA
I have looked @ the fuse box and see nothing that would associate a fuse with the windows. Is there something specific I should look for? I can't find another interior fuse panel. Although the cover does say there is one located @ the "Assist Kick Panel". Does that make any sense to you?
Thanks,
Mar 24, 2009 at 10:14 AM
MMPRINCE4000
  • 8,548 POSTS
Usually on the Corolla it is near your left foot trim panel. Check the owners manual.
Also check the left end of dash, open door and look at left end of dash.
Mar 24, 2009 at 11:09 PM
