1997 Geo Prizm CV joint replacement
250,000 MILES • 4 CYL • FWD • AUTOMATIC
GEOPRISM
My geo has 250000 miles on it and has a shimmy in the front end Iam pretty sure the cv joints are needing to be replaced is this a hard job to do it your self. How much time does it take to do this ,do you need special tools
Jan 31, 2008 at 8:24 AM
MASTERTECHTIM
  • 4,750 POSTS
usually cv joints will make a click noise while turning in corners. the cv boots will be torn and the grease will have leaked out. if you have to replace them its fairly easy job, no special tools needed. the axle will pull out of transmission and new one will snap into transmission.
Jan 31, 2008 at 8:31 AM
