1997 Geo Prizm clutch
1997 GEO PRIZM
BIG J 1973
Drive Train Axles Bearings problem
1997 Geo Prizm 4 cyl Front Wheel Drive Manual
about 3mnts ago i got a clutch installed in the car and now im having trouble starting it i have to slam the clutch down to the floor for it to start someone told me it might be the clutch switch what could it be!
Dec 17, 2008 at 11:26 AM
MMPRINCE4000
  • 8,548 POSTS
Clutch switch is a good possibility. It must closed a circuit for the car to start.
It is on (or comes in contact with) the clutch arm. Generally when you depress the clutch, it releases the switch, which closes and allows the car to start.
Check the adjustment, and replace if needed.
Dec 17, 2008 at 11:36 PM
