1997 Geo Prizm
1997 GEO PRIZM
KINGQN821
Shakes or Wobbles problem
1997 Geo Prizm 4 cyl Automatic 248708 miles
i am trying to figure out why it shakes it only shakes when i go over 45mph then it starts shaking and wobbling really bad was told that i need a front wheel alingment is that true
Nov 4, 2009 at 5:10 AM
MMPRINCE4000
  • 8,548 POSTS
Either an alignment (camber, toe) or a steering/suspension component has failed. Try this first:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Nov 4, 2009 at 9:35 PM
