1996 Geo Prizm Starting trouble
1996 GEO PRIZM
126,000 MILES • 4 CYL • FWD • MANUAL
MARCUS.DOLCE
My dad's Geo prism has troubles starting in the morning. If you depress the clutch and turn the key, you hear a click and then nothing. The battery is not dead. My dad has developed a teqnique where he pushes on the right side of the clutch turns the key and turns the steering wheel back and forth by 60 to 90 degrees and this starts it most of the time. Any ideas? My dad thinks it's mechanical but I think it's an eletrical problem.
Apr 13, 2010 at 3:49 AM
Could be the starter, clutch switch and ignition switch assuming the battery and connections are good.
Apr 21, 2010 at 9:53 PM
