1996 Geo Prizm leakage water
EGYPTMALE
Other Category problem
1996 Geo Prizm 4 cyl Wheel Drive Type unknown Automatic 175000 miles
i found a leak of water coming from the body of the engine not the gasket it is circle in the middle of the back of the engine
Dec 25, 2007 at 6:35 AM
SERVICE WRITER
  • 9,123 POSTS
That would be a freeze plug or also known a s a soft plug or also an expansion plug. Onece you remove it, there are metal or adjustable rubber ones that can be re-inserted...Do not put this off!
Dec 25, 2007 at 12:24 PM
