1996 Geo Prizm Geo Prizm
165,000 MILES • 4 CYL • FWD • AUTOMATIC
ANGELCARGIRL
I have a 1996 Geo Prizm that makes noise when turning the wheel only when its fist started once its warmed up it stops. The belt is good and the fluid is full. It seems to have started once the temp outside got colder. Any assistance would be great! Thanks.
Feb 4, 2010 at 2:06 PM
MMPRINCE4000
  • 8,548 POSTS
Check for leaks at pressure an return lines.
If OK, then remove PS belt, start engine, turn wheel (it will be stiff) if noise goes away, then most likely pump is going.
If you still hear noise, then steering component.
Feb 4, 2010 at 10:40 PM
