Check for leaks at pressure an return lines.
If OK, then remove PS belt, start engine, turn wheel (it will be stiff) if noise goes away, then most likely pump is going.
If you still hear noise, then steering component.
SPONSORED LINKS
Friday, February 5th, 2010 AT 6:40 AM
