My car started to shake when I gave it gas, and has now power at all to get up to speed. I put no. 1 piston to top dead center and the rotor button was pointing to no. 1 plug wire on the distrib. Timming is ok right? The code it gives is PO302 wich says no.2 cyl miss fire. I changed the spark plugs and check for spark at all wires. could I have a blocked exhaust. My next step is to check compression.
Jan 23, 2009 at 10:39 AM
