HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Geo
Prizm
Interior
Instrument Cluster
Gauges
Engine Temperature
SPONSORED LINKS
1996 Geo Prizm
TROIUS
MEMBER
1996 GEO PRIZM
4 CYL
FWD
AUTOMATIC
167,000 MILES
Car started to overheat. Temp gauge inside of car never went over midpoint. Water in overflow bottle was bubbling.
Flushed coolant, then replaced thermostat and radiator. Still overheating within 3 mile distance.
Thursday, July 9th, 2009 AT 9:34 AM
MMPRINCE4000
MECHANIC
Check to make sure cooling fan is working.
When engine is at temp. Use glove and feel if water is moving through thermostat hose.
Perform a compression test to rule out a bad head gasket.
SPONSORED LINKS
Saturday, July 11th, 2009 AT 9:24 AM
Please
login
or
register
to post a reply.
Related Instrument Cluster Gauge Engine Temperature Content
Speedometer Problems
I Believe The Problem Is The Speed Sensor. I Found What I Believe To Be The Variable Speed Sensor On The Transfer Case. It Has One Small...
Asked by
jackcu
1994
GEO PRIZM
1993 Geo Prizm Speedometer
1993 Geo Prizm How Do I Replace The Speedometer On My 93 Prizm?
Asked by
alxweb5
1 ANSWER
1993
GEO PRIZM
1993 Geo Prizm Instrument Cluster Or Vss Problem?
Electrical Problem 1993 Geo Prizm 4 Cyl Front Wheel Drive Automatic 98k Miles So I Bought This Geo Prizm With The Speedmeter Not...
Asked by
aae2288
1993
GEO PRIZM
1996 Geo Prizm Anti Freeze Dumps After 30 Minute...
1.6l This Car Had The Freeze Plugs, Radiator And Hoses Replaced At 110,000 Miles Due To Corrosion And Leaking. It Has Been Fine Since. It...
Asked by
chief455
1 ANSWER
1996
GEO PRIZM
Misfire?
My 1994 Geo Prism's Engine Shakes And Sputters While I Am Driving. As I Push On The Gas Peddle It Moves Slow Like It Does Want To Go...
Asked by
gayle10
1 ANSWER
1994
GEO PRIZM
VIEW MORE
SPONSORED LINKS
Radiator Replacement
Radiator Hoses and Thermostat Replacement
Upper and Lower Radiator Hose Replacement
Online car repair manuals
