1995 Geo Prizm starting
GERALDXS1969
Engine Mechanical problem
1995 Geo Prizm 4 cyl Front Wheel Drive Automatic
im trying to get this car to start without paing 289.00 for a new fuel pump does anyone know a solution.
Mar 3, 2009 at 2:57 PM
MMPRINCE4000
  • 8,548 POSTS
Remove the air intake tube and spray some starting fluid into throttle body, if it starts and runs for a second or two, then fuel pump, or relay.
Should be a B+ and Fp connector on diagnostic link. Jump them and pump should run, if not pump is bad.
Mar 3, 2009 at 11:40 PM
