1995 Geo Prizm Rubbing Noise Suddenly Appears
137,000 MILES • 4 CYL • FWD • AUTOMATIC
PRIZM2356
I have a 1995 Geo Prizm LSi I have had this car for years and it has never made this noise, it started a few weeks ago when I would turn to the right I would hear a noise like something rubbing well withing a few days the noise got much louder. I assumed that something was loose around the wheel well but everything is clear nothing is touching. I have had other Prizms in the past that had bearings and cv joints go bad and none of them ever made this noise. This is the only Prizm I have ever had that had anti-loc brakes. This noise is a rubbing sound. Thanks for any help.[img:8a815bc597]http://www.2carpros.com/forum/automotive_pictures/209768_Picture_166_1.jpg[/img:8a815bc597]
Jul 4, 2008 at 8:07 AM
MMPRINCE4000
  • 8,548 POSTS
If the CV joints and brakes are OK, then have the ABS system scanned for codes. Could be a wheel sensor. Is your ABS light on?
Also make sure the caliper slide pins are not sticking.
Another thing is you can do is take the car to a brake shop and get a free inspection, they may give you some insight into the problem.
Jul 4, 2008 at 11:53 PM
LEE333
I had a similar problem with my 1994 Prizm -- it turned out that the container for windshield washer fluid had broken off a little and dropped down. It took several stops at several mechanics to figure this out.
Jul 6, 2008 at 11:10 AM
MMPRINCE4000
  • 8,548 POSTS
[quote:1bb0881337="lee333"]I had a similar problem with my 1994 Prizm -- it turned out that the container for windshield washer fluid had broken off a little and dropped down. It took several stops at several mechanics to figure this out.[/quote:1bb0881337]
Good point, the container can break loose and contact the drive belts, eventually leading to the spilling of all the fluid.
Jul 6, 2008 at 10:52 PM
