1995 Geo Prizm Cut Battery wire question.
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
GNYNOT
Someone in the neighborhood decided to steal some battery and I was one of the target.
In the first picture I believe they cut the positive cable with the clamp. Will I have to dig under and replace the whole thing?
The second picture shows the negative cable and they seem to cut the top cable and left the bottom part. As you can see they sort of cut some of the bottom one but didn't cut the whole thing. Do I need to replace the whole thing?
[img:4a1e3fcbd8]http://www.2carpros.com/forum/automotive_pictures/430911_IMAG0059_1.jpg[/img:4a1e3fcbd8][img:4a1e3fcbd8]http://www.2carpros.com/forum/automotive_pictures/430911_IMAG0060_1.jpg[/img:4a1e3fcbd8]
[img:4a1e3fcbd8]http://www.2carpros.com/forum/automotive_pictures/430911_IMAG0061_1.jpg[/img:4a1e3fcbd8]
So here is the question. Do you think it is possible to do this myself and will it be a hard task. I don't mind to get dirty.
Nov 4, 2009 at 11:38 AM
MMPRINCE4000
  • 8,548 POSTS
As long as there is enough wire sticking out to splice, you can do it yourself.
Use cable of same size or larger, use electrical solder to complete the repair, then electrical tape to protect splice.
Nov 4, 2009 at 9:32 PM
GNYNOT
What would I put on top of the postive wire?
Nov 6, 2009 at 3:48 AM
MMPRINCE4000
  • 8,548 POSTS
You can buy replacement post connectors at any autoparts store.
Nov 6, 2009 at 9:29 PM
