1995 Geo Prizm code scanner
210,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRZYBOOT
What code scanner do i use for this car. The motor was replaced last year with one from japan for a toyota, now it stumbles when you step on the gas fast.
Jan 11, 2009 at 1:52 AM
MMPRINCE4000
  • 8,548 POSTS
Since this is a 95 it would be OBDI, so you can buy scanners that will scan the system, but they usually are not cheap.
You could find a shop that can scan the car but they will usually charge you $60-100 for a diagnosis.
If you have the equipment, check fuel pressure first, stumbling can be caused by low fuel pressure.
Check spark with a spark testing tool.
If you don't have the equipment above, then look for any shops that are giving free diagnosis (some local chains here where I live are offering free diagnosis for a limited time).
Jan 13, 2009 at 12:47 AM
KRZYBOOT
Thank you for the info, I will check these out
Jan 13, 2009 at 1:13 PM
MMPRINCE4000
  • 8,548 POSTS
You can also short T1 and E1 of the diagnostic port. The SES light will flash the code (flash,flash...pause, flash is code 21).
Jan 13, 2009 at 10:40 PM
