1995 Geo Prizm code scanner
KRZYBOOT
  • 1995 GEO PRIZM
  • 4 CYL
  • 210,000 MILES
What code scanner do I use for this car. The motor was replaced last year with one from japan for a toyota, now it stumbles when you step on the gas fast.
Sunday, January 11th, 2009 AT 9:52 AM
MMPRINCE4000
  • 8,548 POSTS
Since this is a 95 it would be OBDI, so you can buy scanners that will scan the system, but they usually are not cheap.
You could find a shop that can scan the car but they will usually charge you $60-100 for a diagnosis.
If you have the equipment, check fuel pressure first, stumbling can be caused by low fuel pressure.
Check spark with a spark testing tool.
If you don't have the equipment above, then look for any shops that are giving free diagnosis (some local chains here where I live are offering free diagnosis for a limited time).
Tuesday, January 13th, 2009 AT 8:47 AM
KRZYBOOT
Thank you for the info, I will check these out
Tuesday, January 13th, 2009 AT 9:13 PM
MMPRINCE4000
  • 8,548 POSTS
You can also short T1 and E1 of the diagnostic port. The SES light will flash the code (flash, flash. Pause, flash is code 21).
Wednesday, January 14th, 2009 AT 6:40 AM
