1994 Geo Prizm wheel barings
1994 GEO PRIZM
127,765 MILES • 4 CYL • FWD • AUTOMATIC
GANU
how to change my front passanger barings?
Sep 29, 2009 at 12:40 PM
MMPRINCE4000
  • 8,548 POSTS
Corolla wheel brearings are pressed in.
You must remove the knuckle and have a shop press out the old bearing and press the new one in.
You can save some money by removing the knuckle yourself.
You would have to remove outer tie rod, brake caliper and bracket, lower ball joint, pull axle out from bearing, remove strut and then knuckle.
Sep 30, 2009 at 12:07 AM
