1994 Geo Prizm Wheel Alignment
1994 GEO PRIZM
FSA
Tires and Wheels problem
1994 Geo Prizm 6 cyl Front Wheel Drive Manual
My '94 Geo Prizm pulls badly to the left. This after the right Strut was replaced. I have checked the car and I can see where to adjust toe and a camber. I have taken it to three alignment shops and each tells me that a different part needs to be replaced. This lack of agreement leads me to believe that I am going to be billed for something the car doesn't need and I should keep hunting around for a shop that at least agrees with one of the other ones. But I want to be more informed and have been checking up in the internet. So far i have not ben able to find if you can adjust Caster in this model. Where is this adjustment if it exists?
Sep 18, 2009 at 8:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Front and rear camber and caster cannot be adjusted. If caster or camber is off then check for damaged, loose, bent, dented or worn suspension parts.
Sep 18, 2009 at 11:01 AM
