1994 Geo Prizm Vibration Lead to Non-moving vehicle
1994 GEO PRIZM
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CPO3HAWAII
Aloha,
I just got this prizm and I don't know much about the car. However, it had a vibration and in time, it got worst. We changed the Exhaust Piping (thinking that was the problem). Then just a month later, while driving on the highway, the car suddenly stopped dead on the road, but it was still running. When I went to move it, it wouldn't move. Its almost like the brakes locked up. Any suggestions on what might be the problem and also, is this a common problem for these cars?
Thank you, Tina
May 22, 2008 at 8:06 AM
MMPRINCE4000
  • 8,548 POSTS
Check the differential fluid level. Toyota uses a seperate lubricant supply for the transmission and differential (where the axles attach to the transmission).
If the differential has siezed, you will have to rebuild it or get a used/rebuild transmission.
May 22, 2008 at 10:52 AM
