1994 Geo Prizm Motor Silk
1994 GEO PRIZM
123,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUMONSTER
  • 46 POSTS
I could not resist the temptation to buy MotorSilk and add it to the crankcase after changing oil. I hope it will increase mileage a little, protect the engine and most importantly stop the slight vibration I feel on the steering wheel and even sitting on the seat.
It has not helped with the vibration issue so far.
I had the front struts/strut mounts replaced a few months ago and had an alignment done on the car. (Not for this problem) No change.
What can be the reason for the vibration I feel on the steering wheel, on the dashboard and even on the front seat?
Jun 26, 2009 at 8:44 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:78d02aa7f3="BLUMONSTER"]Shakes or Wobbles problem
1994 Geo Prizm 4 cyl Front Wheel Drive Automatic 123000 miles
What can be the reason for the vibration I feel on the steering wheel, on the dashboard and even on the front seat?[/quote:78d02aa7f3]
There are a few reasons....
Worn Engine and/or Transmission Mounts. CV Axles, Tire wear and balance. Check out the link below for more possibilities....
https://www.2carpros.com/car_sounds/vibrations.htm
Jun 26, 2009 at 8:56 PM
