1994 Geo Prizm ABS Light
1994 GEO PRIZM
119,000 MILES • 4 CYL • FWD • AUTOMATIC
JMARIN 49
I did all around break, ck fuses, bleed breaks ABS light is off every time car start ,when start moving comes on , so my guess is wheel speed sensor but wish one how do i txt thank you for your input i like working on my cars 50 yr old yunger day simiskiled need Ohms # to txt each sensor
Apr 2, 2010 at 3:41 PM
MMPRINCE4000
  • 8,548 POSTS
Have car scanned with chassis scanner. ABS generates "C" codes, a scanner will isolate problem.
Apr 10, 2010 at 1:22 AM
MMPRINCE4000
  • 8,548 POSTS
You are probably right about speed sensor, but a scanner will confirm.
Apr 30, 2010 at 1:48 AM
