1994 Geo Prizm
164,000 MILES • 4 CYL • FWD • AUTOMATIC
LEONSTEPH
The right side is fine, its the left side that is bend on my tire, the rims is bent, the axle seems fine, it is just the y or us shaped piece that seems to be pushed in and bent a little bit, how much does something like this ususaly cost
Thank you
Dec 23, 2007 at 10:44 AM
MMPRINCE4000
  • 8,548 POSTS
You would have to inspect the entire front suspension. The lower control arm, ball joint, tie rod, knuckle, bearings etc.
You may be able to replace parts with used ones, but you want to make sure you know what is damaged.
Dec 23, 2007 at 10:51 AM
