1994 Geo Prizm
BRENICE
  • 1994 GEO PRIZM
  • 4 CYL
  • FWD
  • 10,011 MILES
How do I change the water pump on this car
Monday, October 11th, 2010 AT 12:32 AM
Service and Repair
Disconnect battery ground cable, then drain cooling system.
Raise and support engine using tool No. J 28467-A or equivalent.
Remove right engine mount and insulator as outlined under ``Engine Mount, Replace.''
Remove timing covers, then on models equipped with power steering remove front transaxle mount from vehicle.
Remove radiator fan motor assembly, then engine wiring harness retainer clip from engine.
Remove oil level indicator from guide tube, guide tube mounting bolt, then guide tube.
Remove engine coolant temperature sending unit electrical connector, then two nut attaching engine coolant inlet pipe to cylinder block.
Loosen hose clamp, remove coolant inlet pipe from vehicle, then inlet hose from water pump.
Raise engine on vehicles equipped with power steering.
Remove water pump attaching bolts, water pump, then O-ring.
Reverse procedure to install
Monday, October 11th, 2010 AT 6:43 AM
