1991 Geo Prizm thermostat location
1991 GEO PRIZM
81,000 MILES • 4 CYL • FWD • AUTOMATIC
STARMAIL7
Is the thermostat under the upper or lower engine raditor hose housing?
Sep 11, 2008 at 10:14 AM
MMPRINCE4000
  • 8,548 POSTS
The lower hose, under the distributor. Two bolts hold the cover on. Make sure you replace the thermostat with an exact match. The thermostat has a small hole in the thermostat. When installed this hole should be at the 11:00 position.
I would get the replacement thermostat from Toyota, just ask for one from a '91 Corolla.
Sep 11, 2008 at 9:57 PM
