1993 Geo Prizm radiator
SUSANSTERBA
Engine Cooling problem
1993 Geo Prizm 4 cyl Automatic 255000 miles
car just started to over heat when i looked to see why i found a hairline crack about 3 inches long on top of radiator it is about 2 inches from cap. is there some thing i can use to repair the crack until i can afford to replace it
Jul 17, 2009 at 3:12 AM
MMPRINCE4000
  • 8,548 POSTS
You can drain radiator below the level of crack, then clean it with brake clean and use an epoxy like JB Weld to cover crack. Refill radiator after the drying time indicated on the product (usually 24 hours).
Jul 18, 2009 at 12:40 AM
