1993 Geo Prizm geo prizm turns dies when trying to accelera
210,000 MILES • 4 CYL • FWD • AUTOMATIC
THEJAY
my 93 prizm (corolla) stalled and died one morning going to work. I changed ecu,ign coil,distributor cap,map sensor, air intake sensor. before all this it wouldnt start now it will start only if i pull two plugs and dip them in gas. It will idle allday but when i go to accel it tries to die out unless i feather the gas peddle then it will catch up still sputtering now and then. All my research has lead me to fuel pressure regulator or fuel pump. I dont have a pressure guage but i did remove the fuel line going into the fuel rail and it seems to be getting really good incoming pressure, so i guess my question is do the (fpr) has pressure build up on the return..... thank you
Nov 7, 2009 at 12:57 AM
MMPRINCE4000
  • 8,548 POSTS
Check the vacuum line to the FPR, if gas is present, then the FPR diaphram is ruptured and pressure is bleeding off.
But you are right, you have a fuel issue. You should also change fuel filter.
Nov 7, 2009 at 11:58 PM
