1993 Geo Prizm Fuel Lines
1993 GEO PRIZM
109,000 MILES • 4 CYL • FWD • AUTOMATIC
GTRACIN21
How much should it cost to get my fuel lines (high pressure main fuel line, return line and vapor lines) replaced? I'd do the work myself, but I think its more than I can handle. Thanks.
Sep 16, 2008 at 10:08 AM
MMPRINCE4000
  • 8,548 POSTS
Depends on where you get the parts. You will probably have to get the high pressure line from Toyota.
The return line, (rubber) is not very long and you could use Fuel injection line.
Vacuum lines are relitively cheap, but again, if you get new lines from Toyota it could get expensive.
Best idea it to shop around.
Sep 16, 2008 at 9:42 PM
