1993 Geo Prizm fuel
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
INEEDHELP2010
I have a 1992 Geo Prizm. Bought it for 400 bucks. No problems till now. Put new fuel filter, fuel pump, wires, plugs, and distributor cap. I can start the car and it will go ,then all the sudden i have to push the gas pedal all the way to the floor and it will barely go. If i have to go up a hill it wont pull and cuts off. I dont know what to do. Then when i come to a stop, it cuts off. Please help me!!!!!
Oct 5, 2010 at 9:52 AM
  • 75,988 POSTS
Check the exhaust system for restriction and also test the throttle position and manifold absolute pressure sensors-
Oct 5, 2010 at 9:59 AM
MMPRINCE4000
  • 8,548 POSTS
Yes as Raz said, certainly sounds like a clogged cat.
Also check when the timing belt was last changed, change every 60K.
Oct 6, 2010 at 2:00 AM
