1993 Geo Prizm exaust sucks & carb blows
143,000 MILES • 4 CYL • 2WD • MANUAL
ZUKI35
My 1993 GEO Prizm which has had a crank no start problem for a while I just noticed that exaust sucks & carb blows I don't know what could be causing this but i'm pretty sure thats why is not starting. any suggestions about what could be causing this wierd exaust sucks & carb blows problem???
Jun 23, 2010 at 8:22 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Sounds like an exhaust valve and an intake valve stuck open. pull plugs check compression. did this occur sudendly?
Let me know
Thanks for donate
Jun 23, 2010 at 8:53 AM
ZUKI35
I think I have a cheapy compression tester around here somewhere but I can say that it did happen suddenly and it cranks super easy likethere's no compression since it happened. thanks
Jun 23, 2010 at 11:01 AM
MMPRINCE4000
  • 8,548 POSTS
When is the last time you changed the timing belt?
Jun 24, 2010 at 1:12 AM
