1993 Geo Prizm bucking
WC STODDARD
1993 Geo Prizm 4 cyl Two Wheel Drive Manual 125.00 miles
car runs fine untill normal operational is reached..starts to buck ...checked plugs.
Sep 21, 2010 at 3:44 PM
  • 75,988 POSTS
Hi wc stoddard, Welcome to 2carpros and TY for the donation
Do you have a check engine light?
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 21, 2010 at 3:52 PM
WC STODDARD
moisture in the gas tank. added bottle of moisture additive...took care of the problin
Sep 21, 2010 at 4:03 PM
  • 75,988 POSTS
So much of fuel contamination
I'm glad the problem has been resolved and you coming back with the fix so that other people will learn from it-TY-Good Luck
Sep 21, 2010 at 4:06 PM
