1992 Geo Prizm wobbly front end, attention Wizard
CKING
Drive Train Axles Bearings problem
1992 Geo Prizm 4 cyl Two Wheel Drive Automatic
Hi Wizard,
Thanks for the suggestion about the tie rod or ball joint. Do you think the car is safe to drive until the problem can get sorted out?
Jun 4, 2008 at 8:28 AM
  • 31,937 POSTS
Hi there,
If you have a faulty ball joint or tie rod end you should get it repaired ASAP as you may run the risk of a steering or suspension failure while driving the car.
Mark (mhpautos)
Jun 4, 2008 at 5:33 PM
