1992 Geo Prizm
TRAP4U
Engine Cooling problem
1992 Geo Prizm 4 cyl Front Wheel Drive Automatic
my antifreeze has a milky look to it but the oil does not and engine is surgeing also did a compression test on it 2 cylinders were at 150 and the other 2 were 180
Jan 9, 2010 at 11:13 AM
MMPRINCE4000
  • 8,548 POSTS
While compression is withing range, you most likely have a small failure in headgasket, which will not get better.
If it gets worse and coolant gets into oil, you can lose the engine main bearings.
Jan 9, 2010 at 11:36 PM
