1991 Geo Prizm roter
115,280 MILES • 4 CYL • FWD • AUTOMATIC
STEVET1978
how do I remove the rotors to replace broken lug studs?
Mar 13, 2010 at 6:20 AM
MERLIN2021
  • 17,250 POSTS
Removal & Installation (Prizm, Prizm GSi, Storm, Storm GSi & Tracker) Remove caliper assembly. Using wire, support caliper from frame. Remove caliper support bracket from knuckle. Slide rotor off hub assembly. If rotor does not slide off, install and alternately tighten two 8-mm bolts into threaded holes in rotor. To install, reverse removal procedure. Tighten all bolts to specification. See TORQUE SPECIFICATIONS table at end of article. Page 1 of 1 3/13/2010 http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=REPART&YEAR=19 ...
Mar 13, 2010 at 6:29 AM
